What prop is ATJP for ?
Old Mar 19, 2012 | 02:33 PM
gailrider's Avatar
I have a 1992 305 tbi in a jeep that I thought came out of a Camaro. The distributer was pulled when the intake gasket was changed and now there seems to be timimg problems at higher rpms. I was told that it might be a problem with the prom. The prom is ATJP and the ecm is 1228746. Is this from a Camaro or a Caprise and would it effect the stock timing at TDC when out of the loop. Thanks for any info.
Old Mar 19, 2012 | 02:49 PM
EagleMark's Avatar
Re: What prop is ATJP for ?
You can look up chip BCC here:
http://www.gearhead-efi.com/BCCFind/
That one is for 1228746 Caprice. You need to disconnect the tan timing wire and set timing to 0. Turn off jeep, reconnect, clear codes and restart. Timing will then be correct.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
corey8084
Sep 17, 2015 02:56 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
