TunerPro RT v5 changes values on it's own?
Old Mar 28, 2012 | 12:23 AM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
I was wondering if somebody else ran into this problem. I was adjusting the Injector PW Correction vs. Battery voltage values based on the injectors' datasheet and came up with the following values:
Voltage uSec Value
6.4 : 3221.14
8.0 : 2056.71
9.6 : 1564.10
11.2 : 1211.94
12.8 : 978.55
14.4 : 800.80
16.0 : 836.13
Now I make the changes in the proper table, and save the changes and the bin itself. However, when I open the table again, the values are slightly off. I return these values:
Voltage uSec Value
6.4 : 3234.91
8.0 : 2044.71
9.6 : 1556.42
11.2 : 1220.72
12.8 : 976.58
14.4 : 793.47
16.0 : 823.99
I try re-entering my desired values and the tables change on their own again. I noticed that it does it to the VE and the Spark Tables as well. Does TunerPro have some sort of auto-smoothing feature? Or is it because of the way the bin is coded that it can only accept numbers based on coding sequence?
This is on a 730 ECM, 8D code.
Old Mar 28, 2012 | 07:11 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: TunerPro RT v5 changes values on it's own?
You will find there are parameters that have a certain increment of change that is allowed.
It depends on the formula for that parameter. For example, VE changes in the
Low MAP/Low RPM area. Sometimes "zeroing out" the value allows me to input the value I want rather than modifying the existing value.
Old Mar 28, 2012 | 06:28 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
It's the "minimum resolution" effect, ya you get rounded to the nearest available point.
Old Mar 30, 2012 | 05:50 PM
Ok, that makes sense. Thanks guys!
YenkoST
Mar 26, 2007 01:48 PM
327_TPI_77_Maro
29
Apr 4, 2006 09:00 PM
1tpi
Aug 15, 2005 05:22 PM
junkcltr
Apr 23, 2005 03:01 PM
87Formula4bbl
Mar 8, 2005 11:32 AM
