Ned help with offset
Old Mar 28, 2012 | 05:46 PM
Fieroking's Avatar
I have tune for a 89 Chevy Truck. I can read the AZFT.bin file in tunercat. I have replaced the prom in the memcal pack with a EEPROM when I write the bin file to the chip and try and read it Tunercat says the file needs a $ff definition file to read it. I read the original file with a $42 definition file. Because the EEPROM is larger than the original prom I am assuming that I need to enter an offset. I have tried using the numbers that are available on Moates.net with no success. My programmer is a CQ-4 USB programmer. The software only allows me to enter a File Offset and a Device Offset. The file size is 4K.
Can anyone help me please
Joe Sokol
Old Mar 28, 2012 | 06:43 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Ned help with offset
Set the file offset, not the device offset.
Using an SST27SF512 (or other 512 EPROM), the offset would be "F000".
Old Mar 30, 2012 | 05:55 AM
EagleMark's Avatar
Joe Sokol
What ECM are you using now? The 1989 Chevy $42 AZFT is a 1227747 ECM. But you said you replaced the prom in Memcal? That ECM does not have a memcal. You can't use that bin file in a ECM that has a memcal.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
