Differences between 6spd and Auto tunes for LT1s?
Old Apr 11, 2012 | 08:09 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Doing a 6spd swap in my 89 GTA, already have a LT1/4L60E combo in there from a 95' Buick Roadmaster.
My question is whats the real difference between the tunes in a M6 vs A4 tune?
The reason I simply can't load up a factory 6spd f-body tune is because my engine is actually from an impala, so the cam and heads are different.
I know there is a "6 speed" switch in the PCM tune, but is that all there is too it? Just checking the "6 speed" box will cause it to ignore the 4L60E tables?
Sorry if I sound like an idiot, I searched but a 4L60E to T56 change isn't that common of a question in regards to the 94-95 LT1 PCMs. I checked on the CamaroZ28 and Impala SS/Caprice forums but struck out there.
Old Apr 11, 2012 | 11:05 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Differences between 6spd and Auto tunes for LT1s?
there will be other differences, like VSS settings and IAC settings, probably tweaked main spark tables as well.
Old Apr 12, 2012 | 05:25 AM
EagleMark's Avatar
There's so many differences in IAC logic alone between Auto and Manual trans I always start with a bin for the trans. Swapping over any VE, spark tables etc... for the engine should be fairly easy with TunerPro open twice and transferring B body LT1 engine data to F - Y body transmission bin.
I've collected a lot of LT1 bins for 1994 - 95 if you need them.
http://www.gearhead-efi.com/Fuel-Inj...rmation-EE-EEB
Old Apr 12, 2012 | 08:37 AM
I figured as much, just wasn't sure.
That will be very helpful, I now have some more stuff to read now.
Old Apr 12, 2012 | 09:37 AM
Ronny's Avatar
Throttle follower fuel may be in IAC tables.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
ezobens
Aug 19, 2015 10:29 PM
Jake_92RS
Aug 11, 2015 10:39 AM
