tpi bog on opening throttle for wot, ae or pe?
Old Apr 20, 2012 | 03:26 PM
c4mo's Avatar
Having a problem with bog when going to wide open throttle. below is a datalog starting at 8:04 when im am going to wot. Not sure when to start with adjusting ae or pe or both.
File Type: zip
Old Apr 20, 2012 | 09:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tpi bog on opening throttle for wot, ae or pe?
It appears to be more of an electrical issue then a tune issue. And it much different then the last log that you posted. Note how both the RPM & O2 values are jumping around.
Check the EFI harness grounds on the back of the heads. Along with that the battery cables are tight.
RBob.
Old Apr 20, 2012 | 09:04 PM
c4mo's Avatar
I will do it, I noticed that the log also as far as varying rpm. And the bog is worse than it was without any changes. I'll check them
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
