Burn2 not recognized in TunerPro (OK in Flash & Burn)
Old May 23, 2012 | 09:21 AM
R3500's Avatar
Finally bought a Burn2, HDR1, proms and G1 adapter. Only want to read stock Speed Density TPI MEMCALs, then disable functions like VATS, EGR, purge, smog and possibly adjust cooling fan(s) temps. Then burn them.
Downloaded and installed Flash & Burn which detects the Burn2 and reads the MEMCAL. Not sure how to save the bin for editing. Downloaded bins $8D.xdf, 8D MOD.xdf to practice with..but can't locate any windows that allow me to disable any functions.
Installed TunerPro (free version) and I can open the windows (flags) that allow me to disable the functions on the saved bins. Problem is that TunerPro won't recognize the Burn2. I have no problem buying TunerPro RT "if" the Burn2 will work with it, problem might be that the free TunerPro version has no Emulation Toolbar?
Been looking through the stickies but haven't found any answers. Will the Burn2 and TunerPro RT do what I want? To read & write TPI SD MEMCALs? My engines are mostly stock and I only need to disable certain basic functions.
Old May 23, 2012 | 09:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Burn2 not recognized in TunerPro (OK in Flash & Burn)
read the memcal in the flash and burn as a 27c256 and save the buffer as a file. Open the .bin file edit as needed and save. load flash and burn and burn to a sst s7sf512 from
008000 -> 00FFFF .
Old May 23, 2012 | 08:52 PM
R3500's Avatar
tunedperformanc
Thanks for the information, it's printed and in my notebook. Just learned from the TunerPro forum that the Burn2 will only work with the TunerPro RT software (not the free one).
Old May 23, 2012 | 09:21 PM
Engine: Lb9
Transmission: M20
Just a heads up about the hdr1 Im not a fan of that product. It may take several reads until it will save as a 32k .bin, I don't use my burn 2 too read because of the inconsistent reads.
Old May 23, 2012 | 10:16 PM
R3500's Avatar
That's good to know or at least be aware of the potential read problems.
Old May 23, 2012 | 10:19 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
really? i've never had issues like that unless it was a worn out PROM(bad contact), or my 1 instance of a solder joint that failed on the Burn2(repaired myself).
Old May 23, 2012 | 10:52 PM
Engine: Lb9
Transmission: M20
Maybe I should take it apart, i will read different 27c256 memcals with the hdr1 or even a adapter I made from a digikey part and it will read correctly 1 out of 5 times and the other times only show up as a 2k or a 16k with the correct start and end address. I use my trusty old pp2.
Old May 23, 2012 | 10:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Never had an issue with my BURN2 either, and when I thought I had an issue with it, it was just me being a dumbass.
Old May 23, 2012 | 10:58 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
well, should anybody ever note that they need to press down on a specific corner of the PROM to allow it to read/program correctly, take out the whole 2 screws that hold it together and take a look at the corner solder joints, you may see what i did and decided to fix it with leaded solder.
Old May 23, 2012 | 11:39 PM
Engine: Lb9
Transmission: M20
Hmm I will pop it open tomorrow. it has been that way since day one witch lead me to believe it was the hdr1. I used the hdr1 in my pp2 and tried to reprogram though it as well with bad results so I thought it was the hdr1. Thanks for the heads up that thats not normal.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
ULTM8Z
Oct 2, 2015 01:25 PM
lewandom
Oct 1, 2015 08:15 AM
