5.0 vs 5.7 MEMCAL
Old May 24, 2012 | 09:26 PM
waugj's Avatar
Car: 1989 GTA
Engine: 5.7
5.0 vs 5.7 MEMCAL
I recently bought a 89 GTA that someone has put a differant ECM in without changing the MEMCAL, apparently it was out of 89 S-10 2.5. I have found a MEMCAL for an 89 5.0, so I know the EPROM is wrong, but I do have a EPROM on a moates adapter ready to go, but before I buy the 305 chip, I was wondering if the CALPAK portion of it would work on my 350. Thanks
Old May 25, 2012 | 10:16 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: 5.0 vs 5.7 MEMCAL
since the knock filter is external to these ECMs, i would think it will be fine unless you get thrown into limp-home mode.
Old May 25, 2012 | 02:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The netress and the i/0 buffer are the same so Its just a matter of using the correct .bin in 89 the limp home mode netress war altered but even a 86-88 tpi maf memcal will work with the correct .bin
https://www.thirdgen.org/forums/dfi-...0-ecm-box.html
sammy52401
Nov 11, 2015 07:20 PM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
usafirebird
Sep 29, 2015 11:58 PM
lethaldomestics
Sep 21, 2015 01:18 PM
