programmer??
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Re: programmer??
does it come with software?? i didnt see anything to that nature...
what are your thoughts on this one...
http://www.ebay.com/itm/New-Genius-U...ht_2189wt_1334
it has a full manual and software... just to let you know i have read the Prom Intro article
Re: programmer??
Curiosity made me read the English Language manual (which shows pictures of software still in Chinese) and says it supports the old UV Eproms from GM ECMs, but does not list newer EEPROM readily avaialble from Moates we all use.
If your going to start experimenting with cheap chinese stuff, then buy from China, probably 1/3 the price...I've seen some as low as $10. but never seen anyone make it work? This way your paperweight is less costly.
Transmission: 5-speed/T-5
Re: programmer??
I use my BURN2 pretty much exclusively anymore. I do have a Willems GQ-3X on my desk, if I need to program an EEPROM and don't want to dig out my BURN2 from my tuning bag.
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
Re: programmer??
ok guys i am a noob, and completely lost atm. I need to flash my computer to run with a manuel transmission, but i also want a program i can plug into my computer and tune to my wishes, i have a 91 rs 305 tbi and i swapped a manuel trans, what programmer do i need and what prom would be in my car?
Re: programmer??
The only way I know of to flash the ECM is to change it to a flash ECM, may as well start with the best and look at EBL.
http://www.dynamicefi.com/
To change programming on your ECM, depending on what came in your car, would need equiptment noted above for chip or memcal. Have to remove it from ECM to read and program/flash/burn. Moates would have everything needed.
http://www.moates.net/
Car: 92 camaro RS
Re: programmer??
Yeah I hope to go through it soon and edit or add to what is there with working and more modern links soon. It's just a lot of stuff to go through, and will take some time. I've already edited and added a few things.
