outside temperature affecting a/f ratio
Old Jul 25, 2012 | 07:13 AM
c4mo's Avatar
Currently around my area the outside temperatures are 98-100 degrees. During the night they fall to around 85-88. In the hot weather the cars a/f on the wide band is 14.2-14.6. this being stoplight idling and 2500 or below driving, 35-45 mph in town kind of driving. At night it will idle at a a/f of 11.8-12.2, and sometimes a little leaner. Driving light throttle 35 mph or so is 12.5-12.8. Any idea as to why? its tpi, ebl. Thanks
Old Jul 25, 2012 | 07:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: outside temperature affecting a/f ratio
Probably some IAT sensor fueling tables you need to correct. ECM has ways to change fuel mixtures based on intake air temps. Usually hotter air temps gets richer but in your case its opposite and needs corrected.
Old Jul 25, 2012 | 04:11 PM
c4mo's Avatar
i see an iat blend filter, iat/cts compensation, and iat/cts comp bias sa. Which table should i be looking at?
Old Jul 25, 2012 | 04:39 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Lower numbers means richer. So you richen up when the temp drops.
As suggested, looking at the MAT comp tables would be a start.
I would assume this is open loop, correct?
Old Jul 25, 2012 | 05:24 PM
c4mo's Avatar
im not finding any MAT tables of any kind, under another name possibly? No closed loop
Old Jul 26, 2012 | 07:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
IAT/CTS - Blend Filter
The higher the value the more CTS is used versus IAT. The final value is used as the inverse temperature term for the injector PW calculation.
RBob.
Old Jul 26, 2012 | 08:23 AM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
I may be misunderstanding, but if the vehicle is in closed loop during the time when the A/F dips down, I guess you may need to check your BLM status to see if you're maxed in the 160 area? Closed loop should give you consistant feedback across the board, and not drop out of stoich unless a parameter has been reached/exceeded. You may be fighting multiple issues in multiple tables/constants, or you are still in open loop as stated.
Old Aug 7, 2012 | 10:09 AM
c4mo's Avatar
Thanks guys Ill look into these tables
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
