Bin parameter for n/o or n/c fan setting
Old Aug 25, 2012 | 11:05 AM
utilityguy2's Avatar
Having spent the morning researching the 1227165 parameter for controlling the fan relay, I'm still not sure which is correct for 1986 to 1989 F body TPI cars.
I've cross referenced all wiring diagrams which seem to indicate all cars had normally open contacts in the fan relay so I would think that the parameter should be checked for N/O.
But, going through the BIN files for each year it appears that all $32 and $32b BINs had normally closed contacts so it is unchecked. All (or most) $6E BINs had normally open contacts so they are checked.
This doesn't jibe with the wiring diagrams.
I had always thought that all F body cars were Normally open contacts and that all Y body (Vette) were normally closed contacts but now I'm unsure.
Anyone have any knowledge or a place to check this information? I would appreciate it.
Old Aug 25, 2012 | 12:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bin parameter for n/o or n/c fan setting
The difference is in the a/c pressure switch on D11, there is not a standard n/o or n/c for f-bodys although most are n/c and y's are n/o. I have seen in the schematic the switch being wrong as well.
Old Aug 25, 2012 | 12:53 PM
Thanks. I think you mean f bodys are N/O and y's are N/C? Correct? I've looked at all of the 165 $32 bins and the are N/C. Most all $6E are N/O. Are you saying the A/C switch is what determines the open or closed? I thought that only came into effect on second fan and only off of the manual head switch. Thoughts?
Old Aug 25, 2012 | 09:46 PM
Engine: Lb9
Transmission: M20
I think the a/c switch determines the n/o or n/c setting in the ecm. But heres one I did a memcal for a buddy switching from 32 to 6e a while backed he ripped out his a/c so I left it n/o. The fans ran all the time and I had to change it too n/c to get them to function so I don't know the answer for sure.
Old Aug 26, 2012 | 06:49 PM
This is what I have concluded after going through all the Bin files for 1986 through 1992 V6 and V8 F body cars and comparing them with the wiring diagrams.
In all cases, 86 through 87 cars had the n/o fan parameter unchecked so that means they must have n/c contacts in the fan relay. It does not show that in the wiring diagrams nor does it show any connection to the A/C pressure switch. The ECM does receive a ground input from the pressure switch when A/C is on but that's it.
1988 on up are different. The V6 cars are the same as earlier V8 cars in respect to simplicity but they do have n/o contacts not n/c.
5.0 throttle body cars are different with a temperature switch in the head for on and off operation and have one fan with no ECM connection. parameter is n/o but it doesn't matter as there is no ECM control.
5.0 and 5.7 TPI cars have 2 fans with a more complex system where the primary fan is controlled by the ECM and the auxiliary fan is controlled by both a temperature switch and the a/c pressure switch. Kind of a fail safe system. All have the parameter as normally open in the bin. In other words the parameter is checked.
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
TA8487
Aug 16, 2015 12:21 PM
