tunerpro issue
Old Sep 4, 2012 | 04:42 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
tunerpro issue
having problems data logging. With my car, no problems. I can data log and see data with no issues. I plug into a buddies car (actually a 38 dodge with a TPI) and the dashboard in tunerpro cycles between real time readings and max values. sometimes it cycles non-stop, other times 10-30 seconds between jumps in values.
any help would be awesome!
Old Sep 5, 2012 | 01:58 PM
Ronny's Avatar
Re: tunerpro issue
correct def file?
Old Sep 5, 2012 | 02:32 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: tunerpro issue
yes. i'm using the same files we used to edit and burn the prom.
Old Sep 5, 2012 | 02:33 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: tunerpro issue
i should note, i've also swapped ECU's and chip adapters, made no difference.
Old Sep 5, 2012 | 06:47 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
Re: tunerpro issue
i have experienced this on tunerpro V5 and on mine it was not the entire dash, only certain values would do this , the only solution i found (for me ) was to download and use a different adx file , this solved the issue for me, hopefully for you too
Old Sep 5, 2012 | 06:56 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: tunerpro issue
Add the delay (or make it longer) in the connect macro.
Otherwise some setups try to communicate before the last of the previous data has been read.
Here's how to do it
http://forum.tunerpro.net/viewtopic.php?t=2215
Jp
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
