low down on timing
Old Sep 16, 2012 | 10:31 PM
petrolhead's Avatar
Car: '83 trans am Lear Siegler
low down on timing
I've been reading up on timing tables, and as usual, I have more questions than answers. I'm using the ebl on a tbi setup. I have set up many old school distributors in the past, and I know the basics of what an engine wants under different conditions.
Can someone explain what all the different table do in tuner pro? Is it true that I am about -20 deg. than what my sa table is showing? and what about egr?
If someone could give me the basic run down, I could hopefully take it from there. Thanks.
Old Sep 16, 2012 | 10:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: low down on timing
https://www.thirdgen.org/forums/diy-...cs-anyone.html
Old Sep 16, 2012 | 11:55 PM
petrolhead's Avatar
I have read that and understand it for the most part, Thank you! I'm using the v31xdf, and the coolant comp table ranges from around 15 down to around 3 when hot. Do I add this when looking at the main sa table?
Old Sep 17, 2012 | 07:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Both the coolant SA compensation and the CTS/IAT SA compensation tables have a bias value. So the values in those tables get added to the SA while the bias for them is subtracted out.
The WUD SA displayed value is the at-crank timing.
RBob.
Old Sep 17, 2012 | 11:15 PM
petrolhead's Avatar
ok. I understand, thanks. So I can double check my math on the wud at least. Has anyone ever just zeroed it all out?
theshackle
Sep 17, 2020 08:26 AM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
perZ
Aug 15, 2015 01:17 PM
