Can not connect to the ECM (ALDL and tunerpro issue)
Old Oct 11, 2012 | 05:06 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I know there are a ton of threads on the subject and i think ive looked at most of them by this point and seem to have gotten a bit closer to being able to connect to the ECM but im still not there yet. When i go to connect it just says connecting and never actually connects. Things that i have done so far is set the com port to 4 in tunerpro and checked to make sure its the same com port on the computer which it is. 10k resister is in place. I also turned the latency timer down to 1 on com port 4. I have the proper ADX file loaded for my ECM. What am i missing? Car is a 88 iroc running arap bin and 6e def.
Also in another thread i saw mentioned a ALDL setup section in tunerpro. Maybe im blind but i did not see any section like that other than the one that i used to set the com port to 4. Is there another one? It was mentioned in this thread:
https://www.thirdgen.org/forums/diy-...t-datalog.html
Old Oct 14, 2012 | 10:05 PM
lotsofsparepart's Avatar
Car: 1991 S10 4X4
Engine: 1989 TPI 355
Transmission: NV-3500 5 speed
Axle/Gears: 3.08
Re: Can not connect to the ECM (ALDL and tunerpro issue)
I am having the same issue, found this on Craigs site http://support.moates.net/tprtv5-ads-to-adx/
My "Body Size (Dec)" was set to 66 automatically, changed it to 67 and haven't had the chance to try it out yet, but am hoping it solves the issue I am having, which is the same issue you are having.........
Old Oct 15, 2012 | 05:06 AM
subroc's Avatar
Engine: 355 TPI
Ok well i got it to say connected by switching it to autoprom (which is probably not right) but it will say connected even if the computer is not hooked up the the car. That one has me stumped.
I will have to look at setting the other piece to 67. I bet its on 66 now since i never messed with it.
Old Oct 15, 2012 | 07:50 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
What cable are you using to connect to the car?
Old Oct 15, 2012 | 05:42 PM
Car: 1991 S10 4X4
Axle/Gears: 3.08
Changing to 67 didn't solve my problem...... Just says DA Connecting forever.
I am using the cable that came with my Moates APU1, sounds like subroc is using the same.
Old Oct 17, 2012 | 02:08 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
try TTS Datamaster first. I never could connect with Tunerpro when i had my tpi car.
Old Oct 17, 2012 | 02:11 PM
ninetyone's Avatar
Axle/Gears: 3:42
what cable r u using?
Old Oct 19, 2012 | 10:05 AM
EagleMark's Avatar
Increasing body size by 1 will not help you connect. It will help with glitchy/jumpy data.
Try another USB port, mine will work on 2 of 3, sometimes changing between the 2.
Old Oct 21, 2012 | 02:38 PM
Car: 1991 S10 4X4
Axle/Gears: 3.08
Not trying to hijack a thread here as I am having the same issue with the same hardware/software.
Will TTS Datamaster software work with my Moates APU1 w Cable?
Old Oct 21, 2012 | 05:26 PM
subroc's Avatar
Engine: 355 TPI
Well im not really sure what the issue was but i got it to connect. I had a buddy connect it with his computer first then we tried mine and it finally went through. I wish i could be more help and give everyone a reason for why it wasnt connecting but im lost as to what was keeping it from connecting.
Old Oct 21, 2012 | 06:44 PM
Car: 1991 S10 4X4
Axle/Gears: 3.08
Crap!! I still can't connect....... after checking all of the wires at the ALDL port, making certain they had continuity at the ecm connector!!!
I also can't get an OBD1 scanner to connect...... at all......., says unable to communicate with the vehicle.
I am thinking I may have a bad ecm.
When I use a jumper at the ALDL port, I do get code 12 though..... I am so freaking frustrated.
I can't start prom tuning untill I can datalog.
Old Oct 21, 2012 | 11:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
why wouldnt it.
Jae992
Aug 27, 2015 09:07 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
