What would happen if.....
Old Oct 20, 2012 | 10:50 AM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
After my 305 to 350 tpi swap it has become impossible to find a chip that is a 350 with manual Trans. (I know that's because they never made them like that from the factory) but my question is, what would happen if I just put a 350 w/ auto trans chip in my car? Would I get any ses codes? Drivability issues? Performance problems? Any insight from experienced turners would be appreciated as this aspect of my car is very foreign to me.
Old Oct 20, 2012 | 12:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What would happen if.....
If this is your '88, and you also changed to 22#/hr injectors, it will work. Start up may not be the best as there are weight differences between a torque convertor and a flywheel/clutch. Be sure not to use a '89 chip as it has VATs.
If you still have the 19#/hr injectors, then use the 305 chip.
RBob.
Old Oct 20, 2012 | 08:44 PM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
RBob.
Yea they're 22# injectors. I'm just gunna go for it then. I'll post up my results soon
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
