Does ecm stay in PE closed loop after 6375 rpm or go into open loop? $8D 730
Old Oct 25, 2012 | 07:16 AM
msm z28's Avatar
Car: 1991 Corvette
Engine: 406 NA Solid Rlr, Miniram Style Int
Transmission: 6 Speed
Just trying to get a grasp on how the ecm is calculating fuel after 6375 rpm? Does it use last % PE vs RPM in table or go into open loop vs MAP?
Old Oct 25, 2012 | 07:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does ecm stay in PE closed loop after 6375 rpm or go into open loop? $8D 730
PE/WOT mode is open loop, or more correctly a pseudo open loop mode. The INT is locked at 128 and BLM learn is disabled.
Unless the ECM thinks that the TPS is bad, it can then drop out of PE mode.
RBob.
Old Oct 25, 2012 | 07:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
For my old 6e based 383 the pe vs rpm table goes to 6400 and that last entry is held past that rpm. I controlled fuel to 7k just fine however fuel demand after 6400 was slowly declining as i peaked around 6250 in power and held that to 6500 before it was slowly falling off
My 730 ecm code 59 car holds last value in ve tables til redline. 6400 rpm is last entry.
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
HighHopes85
Dec 31, 2008 08:42 AM
