gains from a dyno tune?
Old Nov 11, 2012 | 07:46 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
what kinda gain have you guys seen from a dyno tune?
Posted from Thirdgen.org App for Android
Old Nov 12, 2012 | 10:11 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: gains from a dyno tune?
This would be interesting to know. I have a 91, 305 TPI with a 5 speed and I would like to know what the gajns might be with a dyno tune.
Old Nov 12, 2012 | 10:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Depends on combo. My 11 second 400 whp 383 saw about 10 hp peak but what it really picked up in was mid range around converter stall.
Car was street tuned and it flys thru gears so fast its hard to pick up air fuel data in the 3600-4500 rpm range. On dyno with wideband logging it was very lean. So i richened it up, played with timing and 10 pulls later i was up 30 lb ft torque in that area and about 15 hp. Top end was closely tuned on street and track so not much gain at peak rpm.
That little gain gave me 2 tenths and 2 mph at the track tho. Ran a stronger 1/8 mile
Stock to bolt on L98 may only see 5-10 hp gain. Really depends sone stock tunes are pretty rich and it would respond abit to leaning out. My L98 seemed to pick up about 10 hp from advancing timing alittle and 93 oct gas. Looked to be 1 mph at track.
A big turbo car may pick up hundreds of hp. Thats right hundreds... My friend controls hp by timing on his turbo truck. Same boost level, pulling timing made almost 200 hp difference. max timing was 800+ whp while few degs less made 600's. Exhaust temps were hotter but it was an experiment to see how the motor responds. Use the dyno to see how motor responds to timing and fuel adjustments you may find some big differences
Old Nov 12, 2012 | 10:29 AM
luvofjah's Avatar
Cool, my 305 TPI had the G92 / N10 package, so it has the 350 cam... I have ceramic coated Hooker 2055's, 3" Exhaust, Ported Plenum, coolant Bypass, K&N Filter and an EBL P4 Flash There is a local shop with Dyno, I'll call them up... Thanks!
Rafael
Old Nov 12, 2012 | 10:33 AM
insomniac's Avatar
Engine: 5.7 L98
yeah i went with the crane 2032 cam along with intake mods. considering my car is speed density Id assume it doesent adapt as well as a MAF.... That why im hoping a dyno tune will pick up power and maybe eliminate some of the quirks it has when its cold...
Old Nov 12, 2012 | 10:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well dyno is mainly for warm operation and wot tuning. Cold starting and cold running is sonething that takes alittle more time to do. Can be done on dyno but need to allow time for it. Need car there for a day to cold start and do some driving tuning and then when its warm you can do wot.
Driveability tuning is best done on the street in loaded conditions like high gear and up hills and things like that. Or mustang type dyno that can bear load on drivetrain
Old Nov 17, 2012 | 06:58 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Agree w Orr89. I've picked up 8-12rwhp but the real diff is the area under the curve both for torque and hp.
Also, I do driveability first then WOT tuning. They aren't discrete.
LT1Formula
Oct 8, 2015 08:34 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
