Time to start re-reading all the MAT table stuff
Old Nov 17, 2012 | 10:00 AM
ULTM8Z's Avatar
I've finally been able to add a true cold air set up and get the air filter completely out of the engine compartment.
After moving the battery to the trunk, I used the space to route my cold air tube there and then mount my air filter directly underneath it.
As it stands, I'm running about 25-30° over ambient since there are still paths for hot engine compartment air to reach the filter. But it's about a 40-50° reduction from where I was. No change to the calibration so far but there's a marked improvement in power and throttle response. The 4" diameter tube seems to have counteracted the increased length (I was hoping I wouldn't suffer from excessive pressure drop).
Next step is to get a lower profile air filter, built a box around it and then probably route a tube facing forward (possibly cut a hole in the front air dam).
After that, I'll start addressing the MAT table to see how I can take advantage of this...
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
