VSS and EBL
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
VSS and EBL
With the seemingly increasing difficulty of getting VSS driven gears, could EBL do frequency correction? Input your factory tire size and gear ratios and filter accordingly?
Posted from Thirdgen.org App for Android
Car: check
Engine: check
Transmission: check
Re: VSS and EBL
EBL Flash firmware v 2.2 has a PPM parameter. This will get the ECM MPH correct but not the speedometer's.
The EBL P4 & SFI-6 Flash ECMs which buffers the VSS signal has the same PPM parameter. There is an adjustment for the pulses streams to the speedometer and cruise. However, it is a rough adjustment, not fine enough for speedometer correction.
RBob.
RBob.
TMZIrocZ350
Oct 7, 2015 12:09 PM
