proportional gais vs injector correction tables
Are they related?
I understand the proportional gains are used in the calc for closed loop correction term.
the injector correction is used to account for correction in injector opening times due to fuel pressure voltasge or design of the injector or drivers of same.
How do they relate as far as final pulse width?
Car: check
Engine: check
Transmission: check
Re: proportional gais vs injector correction tables
The only relation I can think of would be on TBI with the PW compensation multiplier versus voltage. As the PW is varied due to prop gains, the compensation of it will also vary.
RBob.
RBob.
