Needham 10 burn on $32B chip
Old Feb 5, 2013 | 07:58 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
First time burning new cal for a friend on his Callaway Corvette TT. Using the stock memcal, and am able to erase. Looking at the chip itself, I can't tell who the manufacturer is, so I amusing a generic chip and 128k which seems to have the correct offset for this 16k bin, 00000- 3FFFF. However, when I go to burn, I get an immediate error at address 0000(Prom ID). The buffer and device values are different. Any hints or tips?
Old Feb 5, 2013 | 11:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Needham 10 burn on $32B chip
27c128 to a sst27sf512 chip start 00C000 -> 00FFFF
are you sure about the setting for that 27c128 if you have some 27c256 I would just use one of those instead.
Old Feb 5, 2013 | 04:20 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Thanks for trying to help out. I am erasing a stock memcal which is taking 2 UV sessions right now. Here are the numbers on the chip:
Here’s the numbers on the chip
0147 5DBB
40581
AA8631B
That’s it. Looking thru the catalog of chips in the Needham program, I don’t see anything like this. Any clues are welcome.
Old Feb 5, 2013 | 08:03 PM
Engine: Lb9
Transmission: M20
You can thank acdelco for not marking all there eprom. That is a 16040581 witch is a 27c128K you may have luck reprograming it with a 27128 setting. They used a grab bag of uv eprom on the tpi maf most are 27c256 programed in the upper half.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
tmellott89
Oct 14, 2015 02:06 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
