Pushing pedal to start cold, ebl tpi
Ive tried searching, but only gathered info on tbi stuff, which may use the same table. Anyway i assume that the problem is iac related. When i start the car cold i have to push the gas slightly hold it, then as warming up slowly release and it idles on its own. When up to operating temperature it starts without help. If this has been covered just give me an idea what to search for. Thanks
Car: check
Engine: check
Transmission: check
Re: Pushing pedal to start cold, ebl tpi
Make sure that on a warm engine and no additional loads that that IAC steps are in the 20 30 range. If not adjust this first.
The IAC position at key-on for cranking is from this table (versus CTS):
IAC - Powerup Init Steps
The baro table is also used as an adder to the above table:
IAC - Init Position vs Baro
RBob.
RBob.
Sanjay
Aug 12, 2015 03:41 PM
