Which .xdf file do I need to use?
Old May 10, 2013 | 08:48 PM
disjaukifa's Avatar
Car: 1984 Chevrolet Camaro
Engine: 2.8L Carb V6 for now
Transmission: 1 speed 700r4 for now
Axle/Gears: 3.42 for now.
Hey Guys,
Actually trying to tune my 88 C1500 that has a 350 TBI system but has an RV cam installed in it, which definition file should I be using?
Grant
Old May 10, 2013 | 09:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which .xdf file do I need to use?
The mask is $42
Old May 10, 2013 | 09:04 PM
disjaukifa's Avatar
The mask is $42
Thank you! I'm trying to improve the gas milage in the truck and one of the things I notice is that the truck kicks out of overdrive very easily, I want to change it so that it stays in overdrive when more throttle is applied. Also I think the truck is running rich as well. ANy advice on stuff to look at?
Old May 10, 2013 | 09:19 PM
Engine: Lb9
Transmission: M20
Look at the low or high speed tcc setting . You need to data log and adjust your ve accordingly . there is a welt of information in the stickies or a gearhead efi the code $42 does not apply to thirdgen.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
