ADX and XDF Questions
Old May 15, 2013 | 08:50 PM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Okay so I'm muddling my way through. Ostrich is working and I can data log...I think. Regardless, I have two custom chips burned (from vendors for my motor) I can't read them. I'm guessing they encripted their chips somehow...(One chip is running fat economy is awful, and it's got a little too much timing. Suggestions?)
SO I have an 88GTA, what ADX and XDF should I be using?
Does anyone have the stock Bin for my car as well. I think it's an AKXZ.
Definitions....How can I convert the information in a bin like ARAP or APYP and look at the data and understand what it means? Like if I'm looking at a timing table, and I know I want say 30 degrees total in by say 3,000 rpm as an example? what does that look like? Or is there a way for Tuner Pro RT to tell me in what the values in these tables mean?
I'm at the stage of learning where I Know what I dont' know....damned near everything...
Old May 16, 2013 | 10:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ADX and XDF Questions
Need files for the $32B mask.
Tuner Pro with the correct XDF will show the values converted for you. Such as having spark advance in degrees BTDC.
RBob.
Bubbajones_ya
Aug 31, 2015 12:02 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
tmellott89
Aug 16, 2015 02:58 PM
