Need this bin: 2.8 v6 \'165ecm (F) Anyone Got It?
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
bl85c is looking for it on his old PC, but I was wondering if anyone else had it?
I need it, and I looked on moates, thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need this bin: 2.8 v6 \'165ecm (F) Anyone Got It?
What bcc was used in the 165 for a 2.8L
Axle/Gears: 10 Bolt
Whats a bcc? The xdf file used is the $32B (v6) 2.8 def
Engine: Lb9
Transmission: M20
Broadcast code, The $32b definition is for a tpi maf v8 87-88
Axle/Gears: 10 Bolt
Engine: Lb9
Transmission: M20
Axle/Gears: 10 Bolt
It's no longer on moates I checked.
Engine: Lb9
Transmission: M20
Eagle mark is hosting the fileman files on gearhead-efi, be patient or start looking through the hosted .bin's.
http://gearhead-efi.com/gearhead-efi/
Axle/Gears: 10 Bolt
The bin files named "2.8 v6 \'165ecm (F)" or "Stock 2.8 v6...something" are not on there...I was hoping someone had them...someone has too.
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Hi. I haven't been active on here in a while, but I just saw this thread. I have my old 88' Camaro ecu and stock prom as well as a hypertech stage 2 prom. I just have to read the prom for you if you still need it?
Randy
Randy
Axle/Gears: 10 Bolt
