Tcc Lock/Unlock
Old Jun 19, 2008 | 12:50 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Tcc Lock/Unlock
When I'm at a steady cruise at 40mph (lockup point) the tcc will lock for 1/2 a second, unlock for 1/2 a second and then relock. I'm fairly certain this is a tuning-related issue, what do I need to change to correct it? 2.8 v6, '165ecm w/ $32B mask.
Old Jun 19, 2008 | 06:09 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Tcc Lock/Unlock
Could also be the throttlecable not adjusted correctly.
Try adjust your throttlecable and see if it helps.
It should not lock, and unlock if you give steady throttle.
Old Jun 23, 2008 | 09:59 AM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Re: Tcc Lock/Unlock
Is this a new problem since you made some tuning changes? Or did it just happen? I've had a bad VSS cause erratice operation of the TCC.
If it is from tuning, you may have to make the converter lock at a higher speed, for me I have it lock at 45-48 MPH, It would just lug and lock/unlock at slower speeds.
Old Jun 24, 2008 | 12:00 AM
bl85c's Avatar
Car: '85 maro
Re: Tcc Lock/Unlock
It started after I lowered the enable point from 45mph to 40mph. I reset the tv cable and I rarely notice it now.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
jklein337
Sep 19, 2018 06:23 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
John Millican
Sep 10, 2001 10:43 PM
