DFCO RPM Drop Exit
DFCO RPM Drop Exit
What does this do? (EBL- L03- auto trans). It is currently set to 50 rpms.
Map exit is 23. So that would be at 0 Map during DFCO map then rises as you increase TPS% and when it hits 23 it exits?
Seems in DFCO rpm would be constantly dropping until you increase TPS%?
It seems like my DFCO is only "on" for a short period of time so I want to maximize it.
Car: check
Engine: check
Transmission: check
Re: DFCO RPM Drop Exit
They are a delta value, used to prevent stalling. With a stick shift just depressing the clutch will cause the RPM to quickly drop and/or the MAP to increase.
With an auto they can both be set higher as the P/N input to the ECM will also cause an exit of DFCO.
RBob.
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
