Will EBL run this?
Old Jun 4, 2013 | 09:40 PM
BLK87Z's Avatar
Will EBL run this?
Guys I have a 92 Chevy Caprice with a built 700R4 Raptor trans and 2800 stall converter. Im transplanting a very healthy vortec headed 355 in place of the current 305. Will EBL run this cam? And can it be tuned? Its a Comp Cams Magnum Hydraulic Flat Tappet 12-213-3 Specs:
Camshaft Specification Table
Part Number 12-213-3
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 292H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.501 0.501
Duration At 0.006 Tappet Lift 292 292
Valve Timing At 0.006
Open Close
Intake 40 72
Exhaust 80 32
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 244 244
Lobe Lift 0.334 0.334
Lobe Separation 110
Old Jun 5, 2013 | 09:49 AM
Ronny's Avatar
Re: Will EBL run this?
I am no expert but it seems in a Carprice this cam is a bit much.
Might need 4.11 gears !
Intake Exhaust
Duration At 0.05 244 244 LSA 110
yes EBL can handle a cam. there are options to tame larger cams at idle or off idle....
eightsixseven
Dec 16, 2024 01:50 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
