Creating a Definition File
Old Jun 29, 2013 | 10:18 AM
camarohelp's Avatar
Where does someone start in interpreting a .bin file? That's something I haven't quite found any information for yet.
Is it black magic? Do people have access to technical information from manufacturers? Is it a blind trial and error process?
Just wondering about the basics.
Old Jun 29, 2013 | 12:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Creating a Definition File
It depends upon which MaskId you want to create a definition file for. Many of them have been hacked and source code created for them. Along with comments of what the calibration parameters are. There are some mistakes in them, but they are a heck of a lot better then nothing.
If there isn't a hack of the MaskId you are interested in, then it gets a lot more complicated. Need to first disassemble the BIN, break out the calibration portion and convert it to decimal. Then figure out what it all does.
Here is a portion of one that I've started a number of years ago. There is the one table that I know what it is, followed by additional data that I haven't yet formatted. But will likely be related to cranking PW:
Code:
; *Crank Mult vs CTS
; pw = base * N / 256
L85B5	FCB	183	; -40
	FCB	165	;
	FCB	117	;
	FCB	 75	;
	FCB	 46	;
	FCB	 31	;
	FCB	 27	;
	FCB	 20	;
	FCB	 16	;
	FCB	 14	;
	FCB	 12	;
	FCB	 12	;
	FCB	 13	;
	FCB	 14	; 116
                     8 131 162 162 178 196 210 230   0   0   0   0   0
 05d0    0   0   0   0   0   0   0   0   0   0 251   0   0   0 251   0
 05e0    0   0 251   0   0   0 251   0   0   0 255   0   0   0 255   0
 05f0    0   0 255   0   0   0 255   0   0   0 255   0   0   0 255 255
Record 000c
 0600  255   0 255 255 255 255 255
Then what the code looks like when first disassembled:
Code:
LB6BE: 86 10		LDAA 	#16		;
LB6C0: B7 01 69		STAA 	L0169		;
LB6C3: 7F 01 6A		CLR  	L016A		;
LB6C6: 15 51 34		BCLR 	L0051,#$34	;
LB6C9: FC 3F BC		LDD  	L3FBC		;
LB6CC: C4 FB		ANDB 	#$FB		;
LB6CE: CA 08		ORAB 	#8		;
LB6D0: CE 40 04		LDX  	#$4004		;
LB6D3: 1D 00 0C		BCLR 	0,X,#$0C	;
LB6D6: FD 3F BC		STD  	L3FBC		;
LB6D9: CC 04 CD		LDD  	#1229		;
LB6DC: DE C8		LDX  	L00C8		;
LB6DE: 03		FDIV 			;
LB6DF: FF 01 6D		STX  	L016D		;
To which it gets commented as it is figured out. Starting with the ALDL list data is a great start at what many of the RAM variables are. Which helps in figuring out what the code is doing.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
dusterbd
Sep 29, 2015 08:40 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
