Tell me I am all good. :)
Old Jul 2, 2013 | 06:51 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Well I have an 88 iroc auto lb9 all stock needs restore. Engine is getting worked on now. Simple clean. All new fuel system (tank,pump,injectors) swapped tranny radiator plugs wire. and it has no cat plus cat back I will do headers.
I pulled the trigger on a tuner and bought the moates 3-1 APU1, plus the hdr module and g1 header. I assume this is all I need to get started ( I Hope)
So I can read the stock bin from the HDR, install the g1 header, tune real time with the APU1 or datalog offline and tune, then burn a new chip when done and install it into the G1 header when complete?
Then are the chips re writable?
Old Jul 2, 2013 | 06:53 AM
jjcuff1's Avatar
Re: Tell me I am all good. :)
Oh I also will be ordering a Wideband. Either Innovate or 14point7.com
Does the APU1 allow feedback from the wideband to be datalogged into the APU1?
Old Jul 2, 2013 | 09:23 AM
Ronny's Avatar
I sure dont know but is that info available at Moates site? I know the EBL accepts the A/F of the WB(Innovate/TT-1) with an analog input to it. Not sure how available def file can handle that datatream from the WB? WB output I recall is 0-5V. The voltage I believe needs to translate to A/F whereby 0 V is 10/1 and 5V is 20/1. Maybe some one did a patch to allow it to show in datastream. A search may find something. Innovate site may have an answer as well.
Old Jul 2, 2013 | 10:40 AM
jjcuff1's Avatar
Yes I will ask their. More importantly I wanted to make sure I spent $300 on the right setup for my 88. It appears so just double checking. The wideband will datalog by itself or on a laptop standalone anyway so I am all good. But I rather have it in one table if possible. Cleaner way to tune and compare A/F directly against RPM and other parameters.
RS Reaper
Oct 17, 2018 07:52 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
85cmroz28
Oct 4, 2015 09:44 PM
AmorgetRS
Sep 28, 2015 09:33 PM
