85 to late 80's ECM questions
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Newb here, I gotta say....you guys have a TON of info here!!!
I'm looking into doing the ECM swap and so forth. I just picked up a nice 85 silver LB9 Iroc. The car is all original except for a so so paint job from years ago.
I was wondering how many of you guys did this and how hard was it to do. It seems pretty involved, but I'm sure I can tackle it.
Here's a pic the day I picked it up.
It's never seen a winter since new. The car was rust proofed with paraffin wax years ago, there's not a spot of rust under the car!!!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85 to late 80's ECM questions
The moderator Jim, midnight85, Rickey Henderson just to name a few have done the 870-165 swap. beautiful iroc
Car: check
Engine: check
Transmission: check
Mike has documented the swap from the '6870 '85 ECM to the '7165 ('86 - '89 ECM):
http://www.eecis.udel.edu/~davis/z28
He then swapped to the '90 - '92 '7730 ECM and documented it. Can find that on his site too.
IROC is looking good... Keeping them out of the Winter goes a long way to preventing rot.
RBob.
RBob.
Thanks for the compliments guys!! I will send those guys a PM.
Looks I'm gonna be taking the 165 plunge! Wish me luck!
That's the wife!
