Anyone put a wideband on a stock/nearly stock engine?
Old Sep 29, 2013 | 11:53 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I've only run widebands on modded stuff. I'm wondering what kind of WOT AFR something like a nearly stock LB9 runs but datapoints from other engines would probably be helpful (i.e. L98/L03). I've always heard the factory tunes them on the rich side, but how rich?
I'm working with a stock s.d. LB9 that just has headers/exhaust. Curious to know if there are gains to be made by leaning it out at WOT a touch.
Old Sep 30, 2013 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Anyone put a wideband on a stock/nearly stock engine?
Stock calibrations will run the WOT AFR into the 10's. This is done to put out the cat-con. There is power to be had by leaning it out into the 12's.
RBob.
Old Oct 1, 2013 | 08:57 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Thanks for the reply Rbob. Makes sense though an AFR in the 10s is richer than I would have expected.
Have you ever had the chance to quantify the gains (from leaning out WOT) on a stock-ish setup?
Old Oct 1, 2013 | 02:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I haven't, simply because I changed the commanded AFR before I did back to back testing.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
