Looking for a few timing tables? XFI280, XFI268 and for LT4 hotcam
Old Nov 4, 2013 | 12:47 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys like the title says I'm looking for a few of these timing tables to play with and or VIN if you want to share. I'll FINALLY be getting my LT383 (XFI280) together fairly soon and I'd like to get a baseline setup for it while I wait. Also I'll be getting ANOTHER LT1 from a friend to swap Into my 91 using the stock computer and harness (Ebl P4 soon enough) and I'm tossing around either the XFI268 or the tried and true hotcam as the 91 is just my DD. So anybody got any tunes they'd like to share?
Old Nov 4, 2013 | 07:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Looking for a few timing tables? XFI280, XFI268 and for LT4 hotcam
Real LT1 motor with factory style LT1 heads? If so they seem to like timing. Like a vette 113 head.
I did a 280xfi on an afr 190 head thats very similar to ported 113 or lt1's and it liked 40 deg around cruise maps and lower rpms, had 28-30 near idle bands of 700-1000 rpm ramping in quickly to 40 by 1600-1800 or so. Wot was 36 deg all in by 3000. Heavy throttle areas in between ramped down from 40 to 36 slowly. Higher rpm no load vacuum areas were 40-42 deg
But this was a low comp 360" sbc deal. High comp high dynamic comp stuff will not tolerate as much timing in certain spots so becareful
Heads determine what a motor wants for timing as burn efficiency/characteristics determine cyl pressure and timing will go hand in hand with that to find how much pressure your fuel will tolerate
Old Nov 4, 2013 | 08:00 PM
Both engine are real LT1's. The 383 will have about 10.1 and the stock LT1 should be at stock compression..
Old Nov 18, 2013 | 09:24 PM
Anybody? I just need the timing tables. The fuel I can do on my own.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
