Moates Chip rewritable and where start address
Old Nov 11, 2013 | 09:48 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
OK
I have a Moates APU1. I have been monitoring and datalogging getting used to the system. I am still unclear about several things but I am getting better.
For starters I am not totally sure in emulate, if I make a change live like remove EGR, does it actually do anything live or do I have to burn a chip first. Hard to tell (I have not made an real changes live yet) Any ideas something to verify I am reading/writing live in emulate?
I think I have correctly download my bin using memcal and use the 32$b def file to read and play with it in emulate. I like to go ahead and disable egr,AIR, VATS, cold start and burn to a chip so I have a good start to rip that crap out.
then tune with a wideband just driving around to dial the timing and A/f a little bit for better start and drivability.
SO my question:
I think I use tunepro to tune the bin the way I want, then use APU1 not connected to car and burn to the c2 chip. then just plug in the new chip to the g1 header? then if I need to I can remove and reflash and reburn again?
I have a G1 adapater and 2x c2 SST27sf12 chips
from Moates. Are these rewritable?
Old Nov 11, 2013 | 09:49 AM
jjcuff1's Avatar
Re: Moates Chip rewritable and where start address
Oh and the other question is the address. I have played with the chip load from Memcal but it ask for the address start/stop
What is the address start stop for the c2? for the stock 165 chip?
Old Nov 12, 2013 | 02:33 PM
phonedawgz's Avatar
If using a 27SF512 in place of the stock 27C128 your start offset would be 00C000 and it will end at 00FFFF. If your program is only looking for 5 digits drop the leading zero.
Old Nov 12, 2013 | 02:42 PM
jjcuff1's Avatar
Cool thanks. The stock 27C128 is what the stock chip is for the 165 ECM and memcal, correct?
What software should I use to burn/reflash? Just tunerpro?
Old Dec 13, 2013 | 11:19 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
I've been using Moates Flash n Burn,
http://support.moates.net/flash-n-burn/
and here is a chart/ explination for the chip offset thingy
http://support.moates.net/programmin...using-offsets/
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
drathaar907
Aug 6, 2015 04:20 PM
