BLM inverted?
Old Jan 22, 2014 | 07:56 AM
widarsson's Avatar
Car: 1988 Camaro 11.08s / 130.5mph
Engine: 383 HSR
Transmission: 700 R4
Axle/Gears: 9-bolt 3.27
BLM inverted?
Maybe a newbie question but please bear with me...
I was logging at idle yesterday and discovered something that puzzles me.
Shortly after it went into CL the BLM dropped to 108 (which should indicate rich right?) and the PW went down.
At the same time the WB O2 showed an increasing lean condition, it went from around AFR 14 up to AFR 17-18.
The NB O2 also showed a lean condition with low volt readings.
Commanded AFR was appr. 14,7
When I blipped the throttle the NB and WB showed rich as they should.
The BLM went up showing lean?
I canīt figure out how this corresponds to each other. I thought that the BLM should be around 128 or at least go up when the NB and WB shows lean?
It might show a little bit lean at idle because of cam overlap and therefore add fuel but BLM decreases fuel instead.
Any help is highly appreciated!
Maybe this is a correct behaviour of the BLM?
The engine is a 383 with HSR, Brodix heads, flat tops and XFI280 cam.
Iīm running a modified Arap-bin, MAF-system.
Old Jan 23, 2014 | 12:55 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: BLM inverted?
Hi..
At idle I think you should tune it in "Open loop". Tune it so It wont smell gas and has a good Idle, WB AFR could be 13 or 17.... ex my car idles at 17-18 AFR anything below that makes it smell gas.
WB vs NB O2-sensor, NB is depending on temp also and could be tricky to trust with a big cam.
BLM wont change with a blip on the throttle, its "long term" adjustment. And when you bllip on the throttle you activate AE and that should make it rich.
I turned off closed loop a few years when I started to tune current engine, never turned it on again
Old Jan 24, 2014 | 01:33 PM
Ronny's Avatar
Re: BLM inverted?
NB and WB read 02. If you are filthy rich it may be reading unburned 02. As stated do you smell rich at idle? Is it possible the tune is way off at idle? As stated I would try OL and see if you can get consistant A/F at 14.00/1 at idle by tuning...low load crusing may be a lot easier to get 14/1-15.0/1...
Old Jan 25, 2014 | 04:22 AM
widarsson's Avatar
Engine: 383 HSR
Re: BLM inverted?
Thanks for the replies.
I will try OL and discard CL altogether. Itīs probably easier to get a decent tune that way.
BR
JWi
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
romcjr
Sep 17, 2015 05:18 PM
ULTM8Z
Sep 16, 2015 09:15 AM
CORV3TT3
Aug 23, 2015 11:26 AM
