How do you measure load?
Old Jan 24, 2014 | 11:08 AM
DanielRicany's Avatar
Hi guys, how do you measure engine load in Tuner Pro? Can it be done using the dash display? I want to modify a Fuel/Air Vs. Load table and I would like to be able to see load values, or maybe at least know how to calculate them? Thank you!
Old Jan 25, 2014 | 03:01 AM
tequilaboy's Avatar
Re: How do you measure load?
LV8 represents gm/cyl and can be approximated by: MAF (gm/sec)/rpm * 4800 (limited to 255) neglecting filtering effects.
Old Jan 25, 2014 | 05:41 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
LV8 isn't transmitted over the datastream?
also, i'm fairly certain most/all masks that use MAF/LV8 have a global LV8 scalar that will skew the value up or down. since LV8 essentially acts as a "airmass in cylinder" value(much like OBD2 grams/cyl), you end up with something that allows for choosing your own range/resolution for anything that depends upon LV8 for reference.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
efiguy
Sep 27, 2015 01:30 PM
