TunerPro RT 5 Problems Datalogging WBO2
Old Mar 27, 2014 | 11:17 PM
hmx's Avatar
hmx
Engine: LO5 350 (TBI 220)
Transmission: 200R4
I have an Innovate LC-1 WBO2 installed, with the DB gauge (connected to the brown wire) and the AutoProm from moates (connected to the yellow wire that has been reprogrammed to be the same as the brown wire) for datalogging. Connect everything, emulating the chip from the AutoProm, no problems. The dash (after I got it set up) works fine, although the AFR shows about 2 higher than the DB gauge.
The problem comes when I datalog. Everything saves fine except the AFRs. The AFRs are displayed correctly on the dash, but show as all zeroes on the datalog.
Oddly, the coolant temp also appears to be bogus, as it started at around 190 deg F, and dropped to 30 deg F as the car ran, which is ridiculous. The other data appears to be OK, though.
I saw that EagleMark had the same issues as myself:
http://www.gearhead-efi.com/Fuel-Inj...unerPro!/page2
I have not seen any solutions to this problem after quite a bit of searching, however, and wanted to drop a note here to see if anyone else has found a solution.
'8746 ECM / $61 / ANLU
Using the 1228746-160baud.adx definition file
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
