VSS in General
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
VSS in General
7730 ECM, 700 R4, believed to be 2-post VSS (2003 Pulses per Mile [PPM} behind a mechanical speedometer (can't see what's there without a lot of trouble)
Have been going through the AUJP $8d VSS code and have some questions. In the process, have read every post on VSS I can find. Lots of info, but nothing consolidated. So here goes initially with some, hopefully, simple questions:
- Short of ripping out the dash, how can it be determined what post-type of VSS is installed?
- Is there anything that can be logged to determine same?
- MPH is reported correctly per GPS, speedometer and via TunerPro (all agree), but the code has the PPM constant L8015=0xE6 indicating 4006 PPM. Does that mean I have a 4-pole VSS, or would MPH be reported correctly with a 2-pole VSS with the 0xE6 constant?
- What would be the constant for 2003 PPM (0xE6 / 2 = 0x73)?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: VSS in General
It's an optical sensor behind the speedo.
Put the speedo wire in C6 on the 7730 ECM and change the constant "to not magnetic"
Car: check
Engine: check
Transmission: check
Re: VSS in General
RBob.
Car: 84 El Camino
Engine: 360 TPI
Re: VSS in General
Also, can you shed some light on what the counter L3FE2 is reporting (AUJP $8d)?
Thanks!
Car: 84 El Camino
Engine: 360 TPI
Re: VSS in General
Right, but forgot to mention that L8018 b6 is set indicating magnetic sensor, so the 4k PPM factor 0xE6 is being used and MPH is correctly reported. My confusion is that with a mechanical speedometer, would not the middle, 2-output VSS in the attachment be installed? Prior owner indicated that's the one. And if so, how is it that MPH can be reported correctly with the 4k factor? Just trying to understand the logic.
Thanks!
Thanks!
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: VSS in General
The VSS input to the ECM can be either magnetic (4 pulse per rev) or optical.
Each has its own scale factor.
The speedometer is operated via an output from the ECM at 2K.
VSS does not directly operate the speedo on the dash.
Jp
The second 2K output from the ECM operates the cruise control (if equipped)
Jp
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
