BPC calculation needed
Old May 23, 2014 | 10:23 AM
Ronny's Avatar
I am converting to port fuel from TBI.
Could someone post the calculation needed please.
I found this on a search but it does not look correct:
displacement of one cyl divided by injector flow rate in grams per sec.
ps 24 lbs per hour= 3.024 grams/sec 5.7L = .7125L
so .2356 ?
Old May 23, 2014 | 01:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: BPC calculation needed
Ronny, don't you have a copy of the EBL Utility? If not I should put it on my web site with a link to grab it.
For an EBL Flash with the Port Mod the BPC for a 350 and 24#/hr injectors is 174 (all entries of the table).
With no Port Mod the injectors fire twice as often, so halve that BPC value. Note that if the injectors are 14 ohms or less they won't fire on a stock TBI ECM. They peak off before they open.
RBob.
Old May 23, 2014 | 02:09 PM
Ronny's Avatar
My EBL is early issue i believe. I dont believe I have utility but will look. I never needed it as I was using one supplied to me prior to my EBL purchase.
I am surprised to see the "174"? I think I understand however?. The TBI was a common plenum to bank to bank. So whether starboard or port side, the firing cylinder will see fuel from alternating injectors and fuel is carried over to next ignition event it being wet vs dry. One crank revolution two injector firings one being starboard and one port side with TBI. With port mod one crank revolution the same two firings one each bank but the firing cylinder is segregated to that bank of injectors. Is that the point?
My current BPC is 87 exactly half of what you calculated.
I will send the ECU back to you soon for port mod.
The Bosch 3's are rated at 39.15 lbs fuel pressure so I will set reg to that.
I will start another thread as to what I will need to address in my EBL.bin it being port fuel.
Thank you.
Old May 24, 2014 | 09:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The early release has the spread sheets to calc the BPC values. Separate ones for port and TBI. When you send the EBL Flash ECM in for the Port Mod, the ECM firmware will also be updated. A new CD will be included with the latest files on it that you will need to use.
Be sure that you have copies of the BINs that you are using.
As for the injectors, I may have the compensation data for them. Need to know the numbers on the injectors plus the color of the injectors.
RBob.
Old May 27, 2014 | 10:32 AM
Ronny's Avatar
Wont be long. Unfortunately all three of my cars need to have minor service this week. I received the compensation data from FIC in an email. Bosch 3's 24 lbs. Great service there.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
