minimum pulse width
Old Jun 10, 2014 | 09:52 AM
Ronny's Avatar
minimum pulse width
My port fuel injectors(M9532AA302) @ 24 lbs fuel/39 psi FP are published at .521 milli secs. I will be using them first in my 350 soon and then next year in a 377 if all goes according to plan. I dont expect any idle issues.
Currently i am using what I believe to be late model 7.4L injectors rated 75 lbs at 12 lbs FP part #12112560.
What is the minimm repeatable PW for this injector?
I believe I am at 1.6-1.7 msec at idle currently. Is there a setting/constant in EBL that can reduce the minimum? It seems that when I change the row of 20 MAP at all RPMs I am still seeing 1.6-1.7 for DE as well as DFCO yet the lights are lit in WU and both I believe are enabled.
Old Jun 10, 2014 | 12:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: minimum pulse width
Post the fuel pressure you are going to use and I'll crunch the data for the injector compensation values. Also note that when going port on the EBL Flash, there are different entries for some of the injector values. Some for TPI, and others for port.
Also, with the Port Mod, the EBL ECM will go to single fire mode once the injector PW gets small.
RBob.
Old Jun 10, 2014 | 12:12 PM
Ronny's Avatar
FIC provided the inj comp values as part of the sale. I was just wondering if I can get my TBI injectors to a lower PW....Moot point in another month....
Old Jun 13, 2014 | 10:20 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
RBob.
Is this perhaps why I may see decel going lean, even w/o DFCO active? PW is so small it's going asynch?
Old Jun 13, 2014 | 10:35 AM
Ronny's Avatar
What if you disallow asynch? flag?
Old Jun 13, 2014 | 01:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
LT5 is SFI, it is already single fire.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
