Lower and Upper VE table Histograms.
Old Jul 1, 2014 | 08:14 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
When using TP RT ver 5, took a datalog, then play it back for review. Using $8D on '90 C4, I have 2 histogram tables set up, one for lower data and one for upper. I am wondering about the row of data for 1600 rpm. Data does not match between both histograms. I know in the actual VE tables that row should be the same in both tables. The lower table has 4 more columns than the upper, but that shouldnt matter.
And also, i do have an extra row in my histogram tables, 1700 for the lower, and 1200 for the upper. Something about the last row of data is invalid, so an extra row is added, and those rows are to be ignored.
This 1600 rpm row is a critical row of data, since the engine sees that rpm quite a bit. So I want to able to tune that row correctly.
Old Jul 2, 2014 | 06:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Lower and Upper VE table Histograms.
I would average the 1600 RPM histogram data between the lower & upper. Then use it and plug the same data into both tables at 1600 RPM.
RBob.
Old Jul 2, 2014 | 11:36 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Originally Posted by MikeT 88IROC350
...And also, i do have an extra row in my histogram tables, 1700 for the lower, and 1200 for the upper. Something about the last row of data is invalid, so an extra row is added, and those rows are to be ignored.
This is correct.
When you are logging and the "reading" is out of the table range, The value will report in the highest/lowest cell of the histogram.
Adding the extra rows ensures that the reading you see is truly from that RPM level and not just being at the end of the table.
Without the extra row, the 1600 RPM data would be useless for both tables.
The 1600 RPM rows tend to get different BLM when going up and coming down so I usually avg out the two readings and enter the middle value into both tables.
HTH,
Jp
Old Jul 2, 2014 | 07:22 PM
Car: 1988 IROC-Z
RBob.
Interesting solution, never thought of that! But easy to do. I have the BLM to VE calculator spreadsheet, so just need to do some math and get the averages.
In fact, might work out better, since the row of 1600 doesnt always have BLM history data in both tables, so by averaging, i will get the best of both worlds!
Old Jul 3, 2014 | 09:48 AM
JP86SS's Avatar
I have some example files for you to look at. Maybe we can finish the tools.
Much of my stuff is done to the point "I" can use it but not as easy for someone else. Little clean up is all that is needed.
Jp
Old Jul 3, 2014 | 08:48 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
RBob.
Ok, that's interesting because in the LT-5 bin, we have upper and lower tables but also Closed and Open Port Throttles. This helps in reconciling the inconsistency between lower/upper.
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Antips16
Oct 30, 2015 06:42 PM
ULTM8Z
Sep 16, 2015 09:15 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
