7427 MAF Conversion Issues
Old Aug 1, 2014 | 11:04 PM
94K2500's Avatar
Car: 94 K2500LD
Engine: 5.7l TBI
Transmission: NV4500
I have a 94 K2500 with a 5.7l and a manual transmission and have been running a 7427 PCM for a while now. I decided to add a MAF to it, finally got everything installed, burnt first chip w/MAF bin and it fired right up, idled real smooth, seems to run smoother when driving also. My problem is that neither the O2mv nor the MAF frequency shows up in TP, both remain at 0. I have double checked everything and it is all connected correctly. TP does show the grams/sec though. I have no failure codes for either of these, so I was wondering if anyone had any ideas what to look for. I checked both signals and they are present entering the PCM, saw MAF frequency change with a frequency counter, grams/sec that is displayed matched the frequency on meter, and saw o2 voltage change also. I have also tried removing the TBI hat, which would allow un-metered air to enter, and moving the throttle which would cause the engine do die then. So I'm pretty sure the MAF is being used and it has not defaulted back to SD. It almost appears that the adx file is not seeing things correctly. I have tried several different MAF adx files with no change. I can go back to a non MAF bin and the O2 shows up correctly with non MAF adx. Thanks in advance for any help.
Old Aug 2, 2014 | 01:35 PM
94K2500's Avatar
Car: 94 K2500LD
Engine: 5.7l TBI
Re: 7427 MAF Conversion Issues
Solved. After more searching, I finally found the answer, https://www.thirdgen.org/forums/di...-problems.html . I guess I wasn't using the right words to search before. Data logs are now working.
specialized
Jun 18, 2022 09:26 AM
777Shock777
Oct 29, 2015 04:30 PM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
