EBL / Tuner Pro causing Flashing CEL! HELP
Old Aug 15, 2014 | 10:06 PM
bigjcfiredog's Avatar
Car: 91 RS
Engine: Vortec 350 TBI
HELP! I am just back to retune my sons car, it is a vortec 355, TBI, aluminum 2.02 heads... GM Vortec intake.
Had it running fine with the cast iron heads, actually ran great... But now when I tried to open Tuner Pro it had been almost a year so I went ahead and updated it.. No other changes. Now If I make any changes to the bin and try and drop it in, the Check Engine Light flashes fast.. If I go back to any of my old files, they don't work very well at all, it drops in fine and runs sorta. The SA is crazy and the VE maps are no where near close... but even if I do a VE Learn it wont take the VE bin. SO now I have a crappy running car!! HELP! I tried to reinstall Tuner Pro, and even redownloaded the XDF.
Any one have a clue? I am totally stuck, and the boy now has a terrible running ride to drive to school next week..
XFD is 61v3.
I found that the bins all show that I have 108 cylinders!!! It is weird..
Thank you in advance!
John
Old Aug 16, 2014 | 08:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL / Tuner Pro causing Flashing CEL! HELP
Use the XDF file that was supplied with the EBL system.
Any BIN that was changed with the 61v3 XDF is trashed, delete them.
RBob.
Old Aug 16, 2014 | 08:49 AM
Car: 91 RS
RBob.
Well crap! Is there anyplace to download the correct xdf? I am unsure where my CD is... I will have to look. I only saw the one xdf on my computer. I shall search. If I cannot find it is there a way to get the correct one?
And thanks for the reply RBob.!
Old Aug 16, 2014 | 09:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To get the proper XDF I need to know the EBL ECM firmware version. Do this, with a good calibration bank and the engine running, the bottom of the main screen of the WUD will show the version number (give it a few seconds).
EMail that to me and I'll email back the proper XDF.
If the WUD doesn't show the firmware version, get the latest WUD from the Update page of our web site. Note that you can also do a playback of a data log to get the version information on the WUD.
RBob.
Old Aug 16, 2014 | 11:46 AM
Car: 91 RS
RBob.
OK I found it.. Sweet! Only issue now is that the VE learn doesn't ever turn green... The knock is sweeping and green, but there is no VE learn. Any ideas?
Thanks again RBob!
Old Aug 16, 2014 | 12:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
BLM mode or WB mode? WB mode needs to be open loop while BLM mode needs to be in closed loop. Engine temperature needs to be within the CTS * learn window (Preferences dialog).
RBob.
Old Aug 16, 2014 | 01:05 PM
Car: 91 RS
BLM mode. OK I will see what the CTS is set too. Is it normal to have it log knock and not VE?
Old Aug 16, 2014 | 03:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Don't open the CTS learn window too far, want it at around the normal operating temperature. This is the one in the WUD Preferences dialog.
The knock logging occurs all of the time in the WUD. It doesn't do anything except display the information (retards & counts).
A VE Learn is different in that it creates a new BIN. So it needs to be started as it is important to give the WUD the correct 'learn from' BIN.
The reason there isn't a spark advance learn based on knock, is that 98% of the time the knock is false.
RBob.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
