open loop
Old Aug 23, 2014 | 07:55 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
open loop
good morning,
Can some please let me know if while in forced open loop mode
my spark and pump shot functions still operate as dictated in the .bin?
Also, will changing the stioch A/F ratio in the constants fatten up the open loop fueling?
thx
Jeff
Old Aug 23, 2014 | 10:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: open loop
Which mask are you working with?
RBob.
Old Aug 23, 2014 | 12:06 PM
jjlabinski's Avatar
Engine: shinny 350
Re: open loop
6E
Old Aug 23, 2014 | 02:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: open loop
Originally Posted by jjlabinski
good morning,
thx
Jeff
In $6E the spark timing and AE will work the same in open loop as closed loop.
Changing the stoich AFR value will be an across the board change in the commanded AFR. That is while in open loop.
RBob.
Old Aug 23, 2014 | 02:47 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Re: open loop
COuple comments. I was playing with this. I tried changing the AFR in the constant and it was extreme fueling. Going down was super rich even 14.2 range. What I found that worked a better was leaving teh 14.7 alone and tweaking the mv switch points.
I left mine stock and teh 14.7 and works fine but I can see at idle I might some minor tweak to the mv. I was trying to see if I kept mv stock, and just changed the 14.7 to 14.2 to compensate for e10 would it matter.
Old Aug 23, 2014 | 03:17 PM
jjlabinski's Avatar
Engine: shinny 350
Re: open loop
thanks
I was just looking for reassurance.
dont wanna run lean
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
