Are these AFRs good for cold temp? What would you change?
Old Oct 4, 2014 | 03:50 PM
DanielRicany's Avatar
Hi, I'm trying to do some open loop temperature based tuning. I'm looking to get the best or close to the best AFR for open loop idling. This is what I have come up with so far based on my calculations. Do you think this is acceptable? What would you change?
9.59:1 -40*F - -18.4*F
10.8:1 -18.4*F - 3.2*F
11.03:1 3.2*F - 24.8*F
11.66:1 24.8*F - 46.4*F
11.89:1 46.4*F - 68*F
12.75:1 68*F - 89.6*F
13.8:1 89.6*F - 240.8*F
Old Oct 5, 2014 | 11:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Are these AFRs good for cold temp? What would you change?
Need to give the engine what it wants, not what you think it wants.
RBob.
Old Oct 5, 2014 | 11:40 AM
RBob.
This was calculated from stock GM tables in the tune
Old Oct 6, 2014 | 07:47 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
What he is saying is facts are better than estimations. "Giving it what it wants" is based on fact. Estimations may very well be off. I've made plenty of wrong estimations.
Personally, living in Rochester NY, I take my car off the road for winter. I'm not trying to be a smarta$s, just pointing out, not to worry about conditions you won't ever see. If you live in Minnesota and plan on driving it in the winter, then as temps get lower, base your changes on observable facts. If it's put away for the winter, why worry about it.
Old Oct 6, 2014 | 08:21 PM
Well what I'm saying is according to my calculations, these are the AFRs that Chevrolet programmed into the computer from the factory.
Terrell351
Jun 13, 2021 01:13 PM
355tpipickup
Aug 19, 2015 10:02 PM
89mulletbird
Aug 12, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
