What bin to start with for my setup?
Old Nov 14, 2014 | 03:13 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I am just getting my new setup together and ready to go in the car I will be tuning with EBL and was wondering should I start with a 92 l98 bin or would a y body l98 bin be a better bin to start with because they came with the better flowing alum. heads and what not?
Old Nov 14, 2014 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What bin to start with for my setup?
Is this the engine in your sig? If so I'd start with a TPI BIN (Port Mod) and copy the VE tables over from the base TBI BIN. The HSR is going to produce a completely different torque curve then a TPI intake.
Assuming this is an EBL Flash (not P4 Flash), start with the EBL_F_3005 BIN. That one is set up as an iron head L98 with an automatic.
Then as mentioned copy the VE tables over from the base TBI BIN. Do some fuel tuning and see how it is. Can then try this semi-tuned BIN with the main & extended SA tables copied over from the EBL_F_3006 BIN (L98 w/alum heads & 6-spd). See if that provides better driveability and/or power.
RBob.
Old Nov 14, 2014 | 10:11 AM
Engine: forged 350
RBob.
Okay thanks and yes I will be using EBL flash with port mod and it is for the motor in my signature and thanks again.
Old Nov 14, 2014 | 10:34 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would also switch the iron head spark table out for one from a F/Y car LT1 or a 96 LT4 Corvette.
Old Nov 14, 2014 | 10:50 AM
Engine: forged 350
Okay thanks I will do that also.
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
