tunerpro rt help what to adjust.
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Hi I am new to the whole tuning thing so bare with me. I have tunerpro rt and the moats burner with the g2 adaptor and I just put a 400sbc in it and I want to tune my TBI. Its not a stock one. Its been bored out to flow somewhere around 830 cfm. Trying to fix one problem at a time. The problem I can't figure out is that when I mash the gas pedal to the floor its accelerates "okayish" but then as I slowly let off the throttle it accelerates harder then at wot. What do I need to adjust. I am guessing its a fuel issue and a TPS issue. Any thought or ideas what to change in tunerpro would be great bec I don't know what half of the tables in tunerpro do. Thanks, again I am new and trying to learn.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tunerpro rt help what to adjust.
You don't show a datalog or mention your blm or afr . Start with adjusting ve the ae if needed. Read the DIY stickies
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
www.dynamicefi.com has some great basic tutorials about tuning for our cars... & great products!
Rafael
Rafael
