truck programming
truck programming
i have a 1989 v1500 blazer with a 350 tbi. so far i have done the ultimate tbi mods, i have a 1 inch spacer, power bowl,long tube headers, 3.08 gears for highway(not as slow as some would think) and holley projection intake for the first gen intake bolt pattern( i did not know when i bought it used so i had to slot the 4 holes for it to fit...). I am ready to start prom burning but i have a few questions first. I bought a 400 sbc with a small 269 advertised degrees cam and .445 on both intake and exhaust and will be building that engine.I will start playing with the proms on the 350 to get the hang of it and then move on. i will swap the intake on my block to the 400 and this is where the questions start. I would like to use a 454 tbi on it and would like to know if it is easier to start with the big block ecm or the one in my 350. What year ecm is more desirable for the eeprom use in my application and could a stock 454 ecm work as is on the 400.
thanks
thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: truck programming
You don't list any ecm service numbers, the 127747 was used on 4.3l, 5.0 , 5.7, 7.4L.
For a custome engine build it will not be plug and play. You could always go with the dynamic Eli ebl. For the 400 you would want to start with a 350 tune adjust for the injector size then start tuning in the ve hth .
I've flashed and reflashed well over a hundred times with EBL.
trickster555- I'd suggest EBL since you can learn to tune, experiment, adjust, and flash easily and quickly. That helps a lot when you have a combination that is a bit of a ways off from an existing GM BIN to start with.
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
I have an EBL Flash forn an 1986 camaro with port mod. what do I have to do to use it on a 1989 TBI 5.7 chevy truck do I need to remove the port mod?
thank you
thank you
Car: check
Engine: check
Transmission: check
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
thank you, what are my options I still have the TPI unit but it was for a 5.0.
do you offer that service. I only saw the service to install the port mod.
thank you
thank you
Car: check
Engine: check
Transmission: check
As stated it isn't easy to remove the Port Mod. Install of it is easy.
For a truck you will like the TPI setup. Lots of mid-range torque. Upgrade the injectors, swap out the two injector connectors for 4 in parallel on each driver, check to see if the IAC and TPS connectors need to be changed.
If the fuel pump hasn't been upgraded yet, that too will need to be done.
RBob.
RBob.
83 Crossfire TA
Sep 18, 2015 12:01 PM
david068513
Sep 18, 2015 10:36 AM
