Compatable eeprom?
Old May 22, 2015 | 03:53 PM
garnerm's Avatar
Compatable eeprom?
I used a AT28c256-15pu but I am getting nothing at the ECU, well the only thing I know for sure is I am not getting a pulse to the rail. I was sure it was compatible when I ordered it but now I cant find anywhere that says it is.
I see I misspelled compatible...
Old May 24, 2015 | 12:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Compatable eeprom?
The data sheets show that pins 1 & 27 are reversed from the normal '256 EPROM. This is A14 (address line) and the ~WE/Vpp. If you can program those EEPROMs should be able to make an adapter to swap those two pins and it should work.
A modified socket would work to help swap the pins.
Always look for the SES/CEL blink at key-on to see if the ECM is running from the PROM.
RBob.
Old May 25, 2015 | 05:09 PM
garnerm's Avatar
So if it comes on solid no blink then its not reading the prom?
Old May 25, 2015 | 08:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is correct, no SES/CEL blink the ECM is in limp mode. That is, it isn't running from the PROM/calibration.
RBob.
Old May 29, 2015 | 07:50 PM
garnerm's Avatar
Rbob thanks for the help I ordered some SSTs and I now have it running.
tmellott89
Oct 14, 2015 02:06 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Formula_88AE
Sep 3, 2015 01:47 PM
