new to ebl flash
Old May 23, 2015 | 07:47 PM
1993tpik1500's Avatar
new to ebl flash
a little about what im working with. 1990 chevy k1500. 496 stroker motor, bbc tbi, Ebl flash, initial bin is for the bbc 502 tbi. Truck starts and runs, but having a fueling issue. I did a 5 minute datalog that im hoping someone can look at and tell me where i need to make adjustments
Old May 23, 2015 | 07:54 PM
Re: new to ebl flash
cant figure out how to attach datalog file
Old May 24, 2015 | 09:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Need to zip the .dat file first, then it can be uploaded.
RBob.
Old May 24, 2015 | 05:33 PM
firstdatalog.zip
Old May 25, 2015 | 08:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not sure how big a cam is in the engine, but it is idling rather rough. There may also be a vacuum leak as the idle speed varies and the IAC is at 0 steps most of the time.
RBob.
Old May 25, 2015 | 01:32 PM
Crower hydraulic flat tappet INT/EXH - Dur @ .050” Lift: 240°/248° RR: 1.7/1.7 Gross Lift: .557”/.578” LSA: 108° RPM: 2500 to 5900 Redline: 6400 Procomp 300cc aluminum heads, Scat forged crank, scat I beam 6.385 rods, Probe forged small dome pistons(10.1to 1 comp.). Running 93 octane. Longtube headers, Full true duel exhaust, no cats, flowmaster 40's. Drivers side header is leaking pretty bad at the head. gonna do a header swap. need to go with some mid lenght, long tubes interfere with front driveshaft. All brand new intake/ throttle body gaskets, as well as hoses . Vortec fuel pump, external regulator , mounted in the return line running 19 lbs pressure.
RS Reaper
Oct 17, 2018 07:52 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
85Special
Sep 3, 2015 04:21 PM
