TunerPro RT Injector Flow Rate
Old Aug 16, 2015 | 11:27 AM
tmellott89's Avatar
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
Using a 32B XDF.Flipping through TunerPro i noticed that in the Scalars Injector flow rate is at @ 40psi. I have 36lbs injectors,so thats what i have put in there but ive noticed that my injectors are rated 36lbs @ 43.5psi. Now i found a conversion online and @ 40psi there rated 34.5lbs. It makes sence to me that it would be lower i just want to make sure that its right first. Never thought about it or noticed it before.Could this make much difference? Car runs pretty rich i beleive (no WB yet) but BLM/INT Proves rich.
Old Aug 16, 2015 | 01:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TunerPro RT Injector Flow Rate
Small difference would be noticed. I just plug in what my inj are rated at for the pressure i am running. If you have 43 psi pressure, use 36 and tune around that
Old Aug 16, 2015 | 02:58 PM
tmellott89's Avatar
Alright ill check fuel pressure on the car and set it at what it would flow at that pressure? Even though on tunerpro it asks what they flow at 40psi?
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
Strick1
Sep 4, 2015 07:11 AM
greenyone
Sep 2, 2015 03:39 PM
